buhdda »
https://forums.nicoclub.com/buhdda-u60094.html
Wed Jul 11, 2007 11:08 am
So here is the update on the story. I had an SRS light go on because my garage was getting renovated so that valets park our car the whole week therefore i went to go get my battery checked. In the process of running the check the light went away.
Someone in this forum mentioned that i may have reset my error codes by somehow disconnnecting the battery when checking it. I dont think this happened because none of the TRIP stuff was reset.
At any rate 300+ miles later i went to get my windows tint. And the guy left the doors opens for 3hours+ and the door lights were on. Once i got my car back the SRS was back on.
I tried the battery test thing again, but it didnt work. I tried to disconnect my batteries but that didnt reset the SRS light either. For some reason disconnecting the battery does not erase any of the TRIP/MPG/etc info.
The dealer wants $92.50 to reset the light. If i knew there was something wrong i think it would be worth it, but the fact that the light is there sometimes and not others makes me feel like this would be a waste of money. I hope i can reset and observe, to try and establish the fact taht there is a problem with my airbags before i start spending hundreds of dollars on it.
However, the light is annoying the hell out of me. So i was wondering if any one found a way to access the MES (memory erase system)?
Clutchkick? You seem to know everyhting about these Ms (i know there are others here who know just as much) Do you know how to access whatever it is i need to access the error codes.
PS the secret diagnosis menu shows no error. (preplexes me even more)
