lol the rad...the first time it overheated i thought maybe it was just low on water and it was really really low, but it turned out to be more than thatDirtyGhettoKids wrote:wait... what were you putting water in?
lol, didnt want to see a repeat.That was the most epic thread of all time though.I_Farted wrote:aaaaa only mustang drivers poor water into their motors remember...
try lifting the valve cover off slowly and pry it out
so im just wondering if anyone has a link to this thread, sounds good lolDirtyGhettoKids wrote:
http://mustangforums.com/forum....htmlTK_Encore wrote:ok so sounds like im gonna have to pry and pull, guess it doesnt matter if the cover breaks or whatever because i have a spare....thanks guys
You have to take the valve cover off to take the cylinder head off.SX APPEAL wrote:Um, I know this isn't really the topic of your post, but why are you trying to take the valve cover off anyway?
well the options available on this will fit on a sticky pad sheetSX APPEAL wrote: or doing a compression test or cylinder leak down test to figure out how the water is getting into the combustion chambers,
I'm quite aware you have to take the valve cover off to remove the head. And I'm also aware that its a lot better to find out exactly whats wrong with your car by diagnosing it rather than ripping it completely apart looking for the problem.Dattebayo wrote:You have to take the valve cover off to take the cylinder head off.
Maybe he's going to swap heads and gasket? Noooo, that couldn't be!
The KA has the upper radiator hose going into the intake manifold...bstrd240SX wrote:well the options available on this will fit on a sticky pad sheet
bad intake gasket - only happens on intakes that have coolant passages that come off the headbad head gasket
I was not going to be a d!ck this time and automatically assume the guy did not diagnose his problem. Sometimes people are good like that. Jaded much?SX APPEAL wrote:I'm quite aware you have to take the valve cover off to remove the head. And I'm also aware that its a lot better to find out exactly whats wrong with your car by diagnosing it rather than ripping it completely apart looking for the problem.
By this place? Noooo, that couldn't be!Dattebayo wrote:Jaded much?
