Street_Science »
https://forums.nicoclub.com/street-science-u161977.html
Tue Jun 01, 2010 2:31 pm
Ok So I have a 1993 sr hatch.....
The thing is only running on 3 cylinders wtf?....Well was running as it will not run , and is currently a crank no start condition... Occasionally I will notice a bump in compression and it will run on three cylinders, idle at 2,200 rpms and sound like a wrx lol...
Cylinder number 4 towards the bulkhead has zero ignition pulse....I tested the other three cylinders and have spark...
I resistance tested all four of the coils and they are all within .5 ohms of each other....
I also went as far as swapping a known good coil, and still nothing....
I need to know if the coils is ground controlld thru the ecu as I predict.....
Wondering at the connector with koeo what I should have for readings with my dmm...
I was told from the previous owner that it needs a cam angle sensor ....
Any help will Be great thanx Andrew.....
But found it strange to find that cyl 4 has 0 ign pulse,whereas the three cylinders do...
Now I also have a total of three ecus, which two are labeled "62", and the third reads "63"...IIrc 63 is for an auto sr s14 blacktop.... I currently believe to have a blacktop s14 sr .....
What are the specs for the coils, cas, and voltage at the coil connectors?......
