SR20VE VVL or SR20DET?
dwade10
Car: 1995 Infiniti G20T
2001 Nissan Pathfinder
I've got a 95 G20T and i'm thinking about doing an engine swap and i'm torn between putting in a SR20VE vvl or a SR20DET. Any advice?
VMPhil
Car: 2007 Volkswagen GTI
good luck Finding a VE engine. its better than the standard DE though.
Modified by VMPhil at 1:32 PM 11/17/2008
nametakennow
Car: '06 MINI Cooper S
DET's are generally older and require more maintenance due to their age. VE's are hard to find.
Power-wise, you'll get more out of a DET for less money.
VE swaps are fairly rare, so the uniqueness value is higher.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
dwade10 wrote:I've got a 95 G20T and i'm thinking about doing an engine swap and i'm torn between putting in a SR20VE vvl or a SR20DET. Any advice?
VE's are hard to find? never knew that. Why not do both? Turbo the VE?
spddemon
Car: 2004 Nissan Sentra BaseS
Check this site jgycustoms.com they have a couple of ve's
wishiwasfast
Car: 2006 Nissan Sentra 1.8se
The ve engine is a pain when it comes to wiring and ecm due the vvl (basically vtec for nissans). But if you build it right it can rev to 9k+ and make power all the way. If you want quick cheap power get a det. They're not any harder to maintain than the ve, because both engines are old unless you get a sr20ve v20 or sr20vet but there extremely hard to find and very expensive.
Yellow4g63
wishiwasfast wrote:The ve engine is a pain when it comes to wiring and ecm due the vvl (basically vtec for nissans). But if you build it right it can rev to 9k+ and make power all the way. If you want quick cheap power get a det. They're not any harder to maintain than the ve, because both engines are old unless you get a sr20ve v20 or sr20vet but there extremely hard to find and very expensive.
When I did my VE swap I didn't rewire anything. I just made a few plugs longer and that was it. I wired up a greddy MSS to control the VVL and tuned my ECU for the injectors and MAF. Throw valve springs in and bigger cams if u want to rev to 9k.
spddemon
A sr20ve is a direct swap on an sr20de motor. You can actually just get the head off a ve and swap it out without haveing to remove the engine.
I thought the g20Ts already had a sr20det in them? I could be wrong.
nametakennow
G20T=G20 Touring, not turbo. There has never been a USDM vehicle with an SR20DET.
