SR20VE swap into yr 2000 onwards Sentra with QG18DE
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
alexleong
I'm new here and would really like to find out if the above swap is possible without having to mod the engine mounts. If it is possible from which model should I get the SR20VE engine from? Thanks in advance.
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
Hmmm hard to say but I would venture a not likely. I think you would have better luck if you had a SE with the SR20DE in it and then it should be close. You must have a GXE I am assuming.
alexleong
Yeah mine's a GXE. Thanks for the reply.
El_Presidente
Car: cars
You will need a lot of work to do this. Here is a short list of stuff you will need to start with.
1) Mounts 2) SR20DE transmission 3) ecu and wiring harness 4) axles
You are probably going to need to modify the mounts too.
You could get the gear box from the qr25 and save money and hassles with the transmission mounts and shift linkage cables. it will bolt right in. the tough part is running some new wiring for a computer that will run the new engine.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
