J-Spec Tuner wrote:NA SR's rock hardcore, if you take off powersteering and everything you end up being about 150lbs lighter than having a KA24 with PS and AC. On that note, I dont think an NA SR is worth it unless your going to go with the whole light weight deal.
My dream SR NA build:-Turbo block (oil squirters)-turbo crank and rods-SR16VE pistons-GTiR quad throttle bodies-SR16VE head-single belt lightend crank pully-no ps or AC-chromoly flywheel-NA sr trans (shorter gear)
- Turbo Block- SR16VE Head- SR16VE N1 Cams- Tomei Cam Gears- Cosworth 12.5:1 Pistons- Crower Titanium Rods- ARP Titanium Rod Bolts- 48mm Individual Throttle Bodies- 370cc Injectors- 3" Side Dump- JUN Flywheel
Run that beast out to the tune of about 9500 RPM running on 104, god damn I loves me some high RPM n/a goodness!
