SR20VE head on SR20det???
SR20S13
Car: 1993 Nissan 240sx - SR20 INSIDE....
i was thinking about that...because its got the "VTAK" and all...lol...i was just wondering if that head would go on a RWD sr20det........or the cams??
hmmm idk just bored i guess....thanks for reading...
sommmatt
Car: 1989 Nissan 240SX
Doesn't the S15 SR20 have VTAKZ anyway?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
It probably would, but what good is Variable cam timing if you don't have an ECU to control it? That'd probably pose the biggest problem. The VE has VVL which has variable timing on the intake and exhaust cams, the S15 SR only has the variable timing on the intake cam. Also I don't think the cams will work. The SR20VE is a FWD right? I don't think it has the dowel pins that a RWD needs. Speculation of course since I've never worked directly with the VE but yeah.
SeVa-S13
Car: '05 GTO 6spd
No, it does not bolt on. I think there may be one or two successful VE head-on-S-chassis-block in the world, but it's one of those things that if you have to ask, you'll never get it done.
USsil80
check out http://www.sr20forum.com .. the have some good write ups on putting a sr20ve head on a de/det bottom end.... the problem with the rwd is the solenoids that activate the cams... they would hit the firewall.. you have to relocate them or box out the firewall.. but yea i have looked into this.. though all ve heads are like $1000... still a cool idea though
zrowkewl
Car: 1989 nissan 240sx
i am also very curious,one of my good friends works at a performance shop,and he is thinking about trying to experiment with this.He did mention something about having to use some type of block off plates in order to align the vvl head to rwd sr block.i think if this could successfully be done you would have a serious powerhouse.
E7-S14
Car: ess 14 foo!
why not just do a s14 vtc head?
shift_SRDETuser
Car: 1996 Nissan 240SX SE
E7-S14 wrote:why not just do a s14 vtc head?
just to give you guys an idea about what this does. I have greddy easycams and a gt2871r and make 100 whp more in the lower rpms up till the peak hit at 7200 where the peak is about the same as a comparable s13 sr with gt2871r. So yeah the vtc makes a difference....
