SR20m wont start?
angelscrx
Car: 1992 240sx
Ok so I have a problem somewhere. I bought the car and was told it was possibly the relay. the previous owner replaced the starter and the main power wire to the starter. I replaced the relay in the fuse box where the batter used to be and it still won't turn over. It clicks a time or two but won't start. What else could it be? maybe a wiring issue between the starter and the relay? The harness looks like it needs some attention but I am not good at wiring.
help please
J14cm7
Car: 95 240sx S14 SR20det
Ok ill start before anyone else does....
SEARCH!
No one is just gonna magically tell you whats wrong with your car. Do research and use the FSM
Mofuger
Car: 93` 240SX SE , Among others
Check your grounds on the engine . Also have the battery checked , you might have a bad battery . I had one that showed 12 volts but when load tested it didn`t have squat for cranking amps . These are just a couple simple things I can think of .
