Not completly true. If you want you can get the SR20det from the Nissan Pulsars. They are FWD and will fit with little work (could be alot for you don't know how much you know about engine swaps). You will need to replace the fuel pump and most likly go custom on a downpipe. Piping and everything else is fine. You will also need a custom air intake. Probably some custom work done on the engine harness. Most likly relocation of the battery.AZhitman wrote:That "someone" is not a car guy.
SR20DET was in RWD Silvia (S13/S14) and certain FWD configurations, but neither chassis is even CLOSE to resembling a Versa.
Easier to boost the OEM Versa engine.
maybe but. V as several chance to be performant. It has the potential to be more performant...biggie wrote:Anyone actually tried to measure the engine options versus the engine bay? I'm guessing that almost all engine swaps are going to be tough because of space.
I've said it 1000 times. If you are looking for a perfermance car, find something else besides a Versa. Older cars will cause much less headaches to work on and improve. V is designed for a couple things, performance is not one of them.
Not trying to rag on you but that is the worst grammar I have seen on this forum to date.loyd87 wrote:
As bad as that was, I've seen worse... I kind of think I know what he was trying to saymonkeybear wrote:
I stand by my original post, and have swapped enough motors to know exactly why I said it.AZhitman wrote:That "someone" is not a car guy.
1) No such engine.
2) Anything can be made to fit in anything with enough work.
I'm going to have to say that this is wrong as well. People have S13 SR's in their S14's and drive all day everyday legally. The only guideline that would prevent it is emissions.Ever Victorious wrote:One other minor detail is that it is not legal by federal DOT regulations to install an engine into a car that was built for a chassis that is older than the chassis you are installing it into.
And since there are no CURRENT production US-spec (important detail!) vehicles with an SR20DET, you may not legally install it in a Versa. For street use.
Incorrect. Motor swaps are legal to drive on roads. The only issue you'll have is passing emissions in the state you plan to drive it in, if it even has emissions guidelines. The most immediate problems that you'll run into is the Versa transmission will not be up to the task in most cases. You will need to modify pretty much the entire front subframe and steering and judging by the size of the Versa engine bay clearancing the engine, turbo and manifold and radiator will be difficult, possibly impossible. You will likely need to run a remote mount turbo. The SR ECU most likely cannot read from the Versa's speed sensor so your dash is unlikely to work, not to mention any supplementary systems outside of the car just running. That being said, SR FTW and if you pull it off that'd be awesome.Ever Victorious wrote:
So not only are you axing the warranty, your axing your legal ability to drive on US roads.
Not knowing the first thing about 240SXes (nor having any particular desire to learn anything about them, as I am not likely to ever own one in my life because of how ridiculously expensive they are), I will have to defer to you on knowledge of the engines themselves.redtop91 wrote:
Agreed. CP makes custom pistons so someone would have to spec the pistons and get custom pistons make. Custom grind cams are always a phone call away, as is a custom turbo manifold and I dunno how beefy a Versa Rod is, but if a KA can handle low boost, anything can . Agreed though. Turbo'd Versa is more practical than engine swap.Ever Victorious wrote:Or, to save the headache, find a way to boost or build up the stock engine. Far less wiring and emissions crap to worry about, anyway.
I know a place that could probably make cro-moly rods, knife-edged cranks, etc... if they were needed.redtop91 wrote:
