sr20det wont start.
cary
Car: nissan 240xs
ok guess haven a prob with my 89 sr20det. all it does is just crank and crank but wont start. im getten spark but no gas i replayed wat ever fuses were blowen or bad, and still fuel pump doesn't turn on any tip on stuff i can check before i rip out the fuel pump and check that. any ideas will help me out alot .
batterys good.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Check for 12v at the injectors with the key on. You should be able to hear the fuel pump kick on for a few seconds when you turn the key to on. Also a lot of people tend to mix up the fuel lines onto the fuel rail.
pete_07
Car: 94 s13
yup it could be youre fuel punp
cary
Car: nissan 240xs
ok i fixed the fuel problem the wire come loss on the pump it self. not its still not starten so i pulled a plugs and had my buddy start it no spark lol. so now i got to find out why. back to the search button lol
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
check the Cam angle sensor. and then check the Ignitor
cary
Car: nissan 240xs
mexicanracer03 wrote:check the Cam angle sensor. and then check the Ignitor
its been awhile since i worked under the hood, ignitor? umm cant remeber were that is, info would be nice. srry to sound like a noob
unibody_s13
Car: s13 blacktop
check ur tdc... cas and ignitor...
cary wrote:ok guess haven a prob with my 89 sr20det. all it does is just crank and crank but wont start. im getten spark but no gas i replayed wat ever fuses were blowen or bad, and still fuel pump doesn't turn on any tip on stuff i can check before i rip out the fuel pump and check that. any ideas will help me out alot .
batterys good.
cary
Car: nissan 240xs
weres the ignitor... and wats a tdc?
mexicanracer03
the ignitor is on near the fuel filter and it looks Kinda dimond shape. and it has a 5 or 6 wire plug.
tdc is related to Timming and it means Top Dead Center. this happens when it #1 piston is at the top. check to see if the Dampener is on 0 degrees and #1 piston is at the top.
cary
Car: nissan 240xs
sweet ty for the info ill go check it out
