sr20det wont rev pass 4000rpm
s13_drftone
Car: S13 with sr20det swap
sr20det wont Rev. pass 4000 rpm?? Help.......i just installed a new z32 mafs but still wont rev...
any Suggestion
180fan
Car: 89 fastback
what do you have converting that signal from the z32 mafs to the SR ecu?
s13_drftone
i converted a s13 stock mafs to a z32
180fan
Car: 89 fastback
uh yeah you can't just do that without something like an AFC or an ecu flash to tell it how to recognize the air flow signal.
McRussellPants
Car: 92 240SX
LOLz
s13_drftone
i dont have a AFC but the ECU code is 55 which is no error
180fan
Car: 89 fastback
the ecu isn't that good at picking up mafs errors. what you need is either an ecu that will read a z32 mafs aka chipped or an AFC. no ways around it.
