juvenile138 »
https://forums.nicoclub.com/juvenile138-u121626.html
Sun Feb 08, 2009 4:54 pm
then either its your MAF wiring, throttle position sensor, or maybe a sparkplug/coil pack or injector problem.
MAF wiring and TPS sensor can be verified by looking at the signals on the AFC Neo, find the right screen somewhere in the settings, make sure that the TPS sensor is near 0 when your foot is off the gas, and at like 5 volts when full throttle. there is a calibration tool for that on it also.
also check your timing with a timing light, get a generic spark plug wire and cut it in half to put on your first spark plug then run the wire out the hole and stick the cut off end inside your coilpack, hook the timing light pickup to that wire and check the timing while rotating the crank angle sensor on the side of the head. Do this when the engine is fully warm and idling at ~850 rpm +/- 50. Should be 15 degrees off TDC which is the next to the last tick mark on the pulley counting from left to right as you look down on it standing in front of the car.
Fuel/ spark issues will have to be isolated by pulling the spark plugs and fuel rail and rotating the CAS while key is in on position. this can either be done by turning the starter over or by pulling the CAS out and rotating it by hand, just be sure to remember that the engine has to be on TDC (2nd pulley mark) before you pull the CAS out of the head, and then you have to line up the marks on it before you stick it back in, get back with me or check the FSM for how to do that.
try all those, and you should find your problem.
