QuinGarcia »
https://forums.nicoclub.com/quingarcia-u2230.html
Fri Mar 14, 2003 11:27 pm
I've run a compression test around 165psi on all cylinders. I also pulled the #4 plug and cranked the engine while checking for spark, and it sparked fine then. where can i get an injector for my engine?? I'd rather not replace all 4 of them, but I know for a fact that it's a leaky injector, and it's affordable, then I could replace all of them, but id rather not. How can I check for sure to know if my #4 injector is leaking??? Just put a clean plug in #4 cylinder, leave the engine in the run position, pull the plug, and see if theres gas on it??? any other methods? I was thinking that maybe my coil was dropping spark to that cylinder ocassionally???? maybe? I've got my plugs gapped at .035.
