sr20det wiring????????
inkslingers13
Car: 1985 Corolla Gt-S
ok so i have a wiring harness for a sr20det red top in to a s14, id like to know if i can change it over to a s13 harness. i have a s13 im trying to put a red top into... any help? thanks everyone
inkslingers13
anyone wana give me some advice??? should i keep it? switch it over? or sell it to help fund a new one? if i do keep it, how would i go about switching it over?thanks
inkslingers13
come on guys... someone has to know this
akinaS13coupe
Car: 1992 240sx s13 coupe
So you have an s13 sr20det with an s14 harness? Or is the harness just modified to fit an s14?
inkslingers13
thanks for the interest, lemme find out
inkslingers13
id say its a usdm s14 harness converted over to a red top. any help?
inkslingers13
hey hijacker, if you read this can you please give me some advice? you replied to the other sr20 wiring post but not mine... i just need some help
inkslingers13
ttt
akinaS13coupe
I dont know how much of a pita it would be to use the s14 harness. I would say best bet is to just get a redtop harness and follow the tutorial on heavy throttle's website. I did my own wiring using their writeup and it wasnt that difficult. You have a redtop ECU right?
inkslingers13
yes a sure do, well thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
Its just a matter of taking the harness back to S13 specs. If you know what was altered to make it work on the S14 chassis, just undo what was done and it should work on the S13 chassis. The EFI harness itself, should be altered little to work in the second gen chassis. The only areas I can forsee needing changed would be the EFI -> chassis plugs by the battery, and the ECU -> dash plug.
inkslingers13
thanks hijacker! that answered me ?!!! thanks
joshuasdad
Car: 1996 Nissan 240sx
hey you have that harness still?
