Sr20det wireing help?? lower half of the harness
silviasliderNJ
Car: 93 240sx coupe
i just finally got to swap my sr20det into my car 93se coupe last week..I am havein some wireing issues, My buddy did the wire harness for me it came out great everthing got sottered an shrink rapt, got the top half of the wireing harness in fine..Then I was putting my Lower half of my wire harness in the car the harness that goes to the + battery terminal.I started from the trans an worked towards the front of the motor cliping everything into its clips then, I got up to the fuse box area an i got to a couple clips an wires i dont know were they go nor do i know what they are for? Yet i do have a couple spot in the fuse box were there were wire an now there ar not.
orange wire black line, & brown into clip. then i have two wires a orange w/ blue line & all orange wire?
then i have a yellow wire w/ a green stripe
silviasliderNJ
Car: 93 240sx coupe
bump
CMG
Car: 1989 240sx Hatch w/ Redtop
silviasliderNJ wrote:i just finally got to swap my sr20det into my car 93se coupe last week..I am havein some wireing issues, My buddy did the wire harness for me it came out great everthing got sottered an shrink rapt, got the top half of the wireing harness in fine..Then I was putting my Lower half of my wire harness in the car the harness that goes to the + battery terminal.I started from the trans an worked towards the front of the motor cliping everything into its clips then, I got up to the fuse box area an i got to a couple clips an wires i dont know were they go nor do i know what they are for? Yet i do have a couple spot in the fuse box were there were wire an now there ar not.
Kind of confused about what you're asking and the pics suck. Are you talking about the lower engine harness? That should not have been cut at all. If you're talking about the connectors by the battery, splice according to the wiring guides available here. And some connectors are not used in the swap.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Are you useing the KA lower harness for the SR transmission?
silviasliderNJ
Car: 93 240sx coupe
i am trying to us a sr harness, its the lower half connects the trans an altanator and starter an + side of the batter ..The question is those wires in the photo are loose what should i do with them or were should i plug them, or do i have to cut clips off the ka harness an splice them together?
duffman1278
Try getting better pics of the second one because I dont think anyone can see anything in it. But as for the first, i have no idea, I remember I had like 2 extra plugs left over. You should really only make sure you have your important ones plugged in. there's 3 plugs on the transmission I believe, speed sensor,reverse, nuetral. Than the other connections are to the starter and alternator, than it followes up to the battery tray.
silviasliderNJ
Car: 93 240sx coupe
yeah i got all the clips on the trans and everything up untill the battery tray/fuse box thats were all these wires are...None of them clip into were the old Ka harness clips went into the fuse box by the battery..Sould anything replace were the old ka clips went in the fuse box???
duffman1278
Off the top of my head, they shouldn't. When I did mine, I used the KA harness and spliced in the SR plugs for the transmission. But it should be direct connections iirc.
silviasliderNJ
Car: 93 240sx coupe
so i could use my ka harness but then i would have to cut clips off the sr harness for the trans clips? if im understanding corectly.......... if so can u tell me which clips i would have to cut off the sr harness to splice into the ka harness
silviasliderNJ
Car: 93 240sx coupe
bump
duffman1278
For the KA harness into the SR you have to splice just the nuetral, reverse, and speedometer plugs from the SR onto the KA. The colors match so you could just splice them in really easily. I only have pics of two plugs but I did all three, even though some say you don't need the neutral iirc.
