JustinRB25s13'92 »
https://forums.nicoclub.com/justinrb25s13-92-u255972.html
Wed Nov 25, 2015 8:11 am
You correct, it also depends on how bad the leak...think about this, you may still be able to have power and it may still "pull" pretty hard, but in reality you are turbocharged, so no matter what is happening the other cylinders may still be okay it just depends on how badly the gasket was destroyed and the location....or it could be even dumping a minor amount of coolant in X number of cylinders, but its not enough to be a noticeable loss of power...but another possibility is the turbo its self...theres a myth that shaft seals can allow coolant out, but it would be kinda far fetched....how much boost are you running?
