sr20det water pump
xero1
Car: 08 Altima Coupe
does the sr20det use the same water pump as the sr20de engine?
Silvia007
Car: 93 Nissan 240SX SE Fastback
It's got to be from a rear wheel drive SR20DE, the Sentra SR20 water pumps stick out a little further then the SR20DET's.
xero1
which water pump would work on an sr20det blacktop
robbbby
The one from a sr20det.There are no USDM substitute for the sr20 waterpumps. Order one from courtesy, they are fairly cheap.
