SRJesse wrote:There is also a problem when I start the
car when its not warmed up. If I press on the gas pedal it seems
to want to stall out on me, and will continue to do this unless I let
the car idle for about 3-5 minutes.
it seems that the car warms up fine according to his post. With the last sentence I quoted from SRJesse, the problem is cured about 5 mins. He has no mention of other driveablity problems (hesitation, misfiring, gas mileage).
I've dealt with open thermostats before, not the SR in particular, but generally the car won't warm up at all with a thermostat stuck open.
What you saying are correct, 1991240xs, a bad thermostat will contribute to a ill-performing engine but from what i've read it doesn't seem to be the case. I was trying to point out in my last post that he is having trouble with his engine as soon as it starts in the morning (no time to warm-up). Since the engine is COLD from the get go and he is having problems, a faulty thermostat isn't the problem. I hope this helps you out...
