sr20det want to hit 400whp
miatarb25
Car: miata
hi im planing a build and i want to know the best way to hit 350-400whp on a sr20 would be i plan on doing a full head build but want to keep the bottum end stock what size turbo, injectors and what to do for fuel was thinking of running the new AEM Fuel/Ignition Controller (F/IC). want to make it on pump 93. the engine will be going into a miata.
S14toRPS13
I see you were probably originally going for the RB25. If you go through with your project, you should post it up.
I feel really nice right now, so here's answer to your question. This doesn't happen much, so next time I suggest you click on the search button and type in 400 hp SR. Most people will jump all over you for asking a very typical question.
zerothread?id=213470
playero_loko
Car: 1991 240sx
S14toRPS13 wrote:I feel really nice right now, so here's answer to your question.zerothread?id=213470
what a class from you, way to go...
Justin35ll
Car: s13 coupe sr20det
My goal is to hit 350 rwhp if not more.I'll prob get cams, springs, retainers, do timing belt as well while I'm there, (550cc? injectors), z32 maf if that is good enoughTop mount manifold with a gt28 or gt30 boosting about 1 bar. Not sure how much whp I will see, but I don't want to go crazy while still on stock bottom end
redsx13
Car: 93 240sx 03 350z
miatarb25 wrote:hi im planing a build and i want to know the best way to hit 350-400whp on a sr20 would be i plan on doing a full head build but want to keep the bottum end stock what size turbo, injectors and what to do for fuel was thinking of running the new AEM Fuel/Ignition Controller (F/IC). want to make it on pump 93. the engine will be going into a miata.
My goal is to hit 280whp since thats all my little t28 can handle.dyno next weekend!
Your really need all that hp? its a miata for gods sake, unless its a drag car 400 is impracticle, and if its a DD, which i hope its not, thats just stupid.
redsx13
i say just throw the sr in and enjoy it for a while, then think about serious hp mods. have you ever even driven a 350 or 400whp car that light?
hugogos22
Click on the search Button and you will find your answer and 400HP aint **** on a 240sx. Should feel good in the miata. Word of advise dont stay bottom mount you will end up wanting more and your setup will be maxed out.
hugogos22
Justin35ll wrote:My goal is to hit 350 rwhp if not more.I'll prob get cams, springs, retainers, do timing belt as well while I'm there, (550cc? injectors), z32 maf if that is good enoughTop mount manifold with a gt28 or gt30 boosting about 1 bar. Not sure how much whp I will see, but I don't want to go crazy while still on stock bottom end
Dont but 550cc get 740cc incase you ever want more power. I had them and the idle was perfect
blownSR2087
Car: 95 nissan 240 sx
i have a s14 black top stock internals gt2876r turbo 550cc injectors 255 fuel pump i am pushin 15psi an i dyno about 330 hp and run the 1/4 mile @ 12.987 @ 112 mph i am very proud of my little 240
