SR20DET Want Start.
DriftNismoSilvia
Car: 93 Nissan 240SX SE HB
I just recently installed a Red top Sr in to my 93 nissan 240 and it want start. I have went over all my wiring dia, and double check all the wiring, the main ignition power wires are right (black /w red and blue /w red) are connect together and attached to the black /w red on the main harness. Im still not getting and fire on the coil pack and my ECU is good. can any one please help, also what does the ignitor chip look like on that harness cause I think that might be my problem too, and were would it be located at on the harness?????????????
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
it WONT start or WANTS to start??
what procedures did you use to condemn you weren't getting spark? definitely check the wiring again.
DriftNismoSilvia
It won't start lol and I have used a volt meter on all my wiring when I hooked it up and im getting voltage for main ignition but nothing is coming from the coils. so do I have bad coils or bad ignitor???
DriftNismoSilvia
It won't start lol, and I have check all my wiring with my volt meter and I am getting the reuired reading but im still not getting any fire to the coils, so i wondering if its bad coil packs or bad ignitor chip.
