D1 guy wrote:I have an s14 notchback sr in my 97 240 and Im running nismo 555s that flow at 615cc w/z32 mafs, jwt ecu tune, walbro 255 pump, and a z32 fuel filter. My turbo is the big gt2871r. I also have 256/264 hks cams. Ok heres my question. I dont have a metal headgasket because I figured its better to blow the head gasket rather than blow up my engine. Ive been running 20psi and the car seems fine. My aem wideband shows around 13.6 at full throttle. feels like about 400hp. Is this ok or should I turn down the boost? What is recommended for the factory head gasket? Thanks very much and I did search, but couldnt find a direct answer.
13.6 is kind of high isn't it? isn't around 11.5 ideal?
as you know, my car is working on a pretty similar setup as yours (except i have a 1.5mm metal HG). however, all the research that i have done says that its not a good idea to go over 17psi on the stock gasket.
