homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Fri May 21, 2010 6:17 pm
You're probably going to get flamed, a lot. Keep the car the way it is if you don't have $. A properly done SR swap or KA-T costs a bit of $. Take your time learning about the pros and cons of both by searching for hours on end on the forum. Wait a while (like a year or so) before you swap in the SR or turbo the KA. This way, you'll have a better idea of what you're doing (if you search and use the information contained here). The last thing you need to do with only a part-time job and this little knowledge of either motor, is to jump head first into the pool. You will regret it if you do. Wait, just trust me, hold-off for awhile until you learn. That said, either option will be reliable, if, and only if, you do things right the first time. How to do it right? SEARCH, those answers are contained on NICO and elsewhere. GL
