sr_powered wrote: after the installation of the thermostat, my idle's really rough. it will stall, dropped to almost zero and rised back up to about 900 rpm. it keeps doing that, and on cold starts, the engine will died instantly right after i started it up.
could be throttle position sensor, but I don't think the ECU looks at its values until its warmed up. My TPS was filled with water and was reading all over the place in any single position, so at idle it would rise/fall/rise/fall but it would always cold start and run at 1200rpm like normal. once it got half way to running temperature is when my problem would start.
Check the stock rubber intake tube for any cracks and generally poke around, check out couplers, clamp tightness, make sure any of the 3 tb vaccuum ports are either being used or are capped off airtight, etc... If it's letting unmetered air in anywhere past the MAF, that'll lean it out a bunch and would definitely account for a rough idle. Do you have an aftermarket BOV? My Greddy RS was set up way too loose out of the box and was letting air in at idle. heh.. the reason i got an RS is because the ancient original "pressure bypass valve" on the Sidemount IC was bad and leaking pressurized air back into the intake.
if you haven't done so yet, make sure your O2 wiring is sound.
Take a couple minutes and pull out a spark plug, see what it looks like after installing the t-stat. If the ceramic part around the cathode (or anode? w/ever) is still black it's still too rich. If the ceramic part looks white and the rest is chalky tan, its too lean. On a happily running motor, that ceramic part should be golden brown-ish.
If it's indicating rich, the fuel pressure regulator on the outlet of the fuel rail may be bad, letting fuel pressure build up in the rail so whenever the injectors open too much gas squirts through. Check to make sure the the vaccuum line connecting the FPR to the throttle body isn't dry rotted. Like previously suggested the O2 sensor may just be dead as well. to be sure of that though, you should check the reading at the O2 sense line's pin on the ECU with a multimeter.
also, check your timing! you can rent a light gun from autozone, or just buy one, i think theyre like $30. To use it though you have to cut an ~8" length out of a KA's wire, put the KA wire boot down on the No.1 cyl plug and stuff the cut off end up into the coilpack. this gives you a good place to put the light gun's spark-fire sensor. With the throttle position sensor unhooked, the ECU goes into "set ignition timing" mode. Idle should be at 700rpm when the motor's warmed up with the TPS unhooked. If it isnt, adjust the idle via the IACV adjustmet screw down in between the 1st and 2nd intake runners. Once the idle is at 700rpm, point the light gun down at the crank pulley, the 2nd timing mark from the right (15° before top dead center) should line up with the needle sticking off the oil pump cover. If theyre misaligned, just un-snug the 2 bolts holding down the cam angle sensor and rotate it while still checkin with the gun on the pulley till they line up. then snug the CAS back down, reconnect the throttle position sensor, put the coilpack directly onto the spark plug again and see if anything's better feeling.
If the timing marks are way off, don't worry about setting the idle first cuz it just might want to stall on you worse. get the timing marks ball-park and then adjust the idle and proceed from there.
Every little thing you can do helps you at least figure out what's NOT your problem.
*king of editing posts*
Modified by Neil at 2:59 AM 2/13/2006
