compression »
https://forums.nicoclub.com/compression-u9345.html
Tue May 25, 2004 7:54 pm
An FMIC will not add any power at stock boost UNLESS you get one with a significant less pressure drop across the core (so your gains are from improved flow) or it brings the air temperature down to a level where the computer can advance timing without seeing any knock. This is kind of unlikely because at stock boost levels (about 8psi?) the air is not increasing in temperature that much when it is compressed. In fact I think up to around 5psi, you dont need an intercooler at all ( i read that in spearco's intercooling book). If you want to run more boost, then you have to make sure that the turbo can handle it, and the fuel system can handle it. As far as selecting an intercooler, get the one with the smallest pressure drop and largest heat rejection rate.The BOV does not do anything critical, so dont sweat it. But i would recommend sticking with a GReddy one. The T25 and T28(from a S15 silvia) use all the same flanges, the only difference is that the compressor inlet flange is at a different rotational orientation than the T25, not a big deal.If you want more power, then you will need more air and more fuel. You cannot add one without the other.For added fuel you will need larger injectors, a way to control the larger injectors (stock computer wont work, needs to be reprogrammed, or piggybacked), and probably a larger volume fuel pump, and probably an upgraded MAF sensor (as stated in the previous post).Basically, there is a lot that has to happen in order go above stock boost levels.
