sr20det turbo piping question
Gazou
Car: z31 and s14
Hi , I am trying to know if the side mount intercooler and the piping is the same on a s13 and a s14 , I know the pipe from the intake manifold of the s13 -s14 is different because of the high port intake and low port , but are the other pieces the same , and can I fit them on my s14 with a s14 sr20det .
Is the sidemount intercooler the same also, I am about to swap an sr20det s14 in my car and there is someone selling all the piping and sidemount intercooler from a 180sx .I have search the internet for this information and did not get some clear information ,thanks
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
The s13 and s14 piping is not exactly the same.The hot pipe that connects to the compresor outlet on the s14 is about a 45 degree angle and the s13's is a 90 degree if that makes sense. So unless you cut and wield it its not going to line up. And the cold pipe side will be different like you said because the different positions of the intake manifolds,but im sure you could cut it and modify it to fit.
