240life »
https://forums.nicoclub.com/240life-u76914.html
Fri Aug 14, 2009 6:07 am
OK so I just fixed my engine had pulled everything out reinstalled everything, I started it up and either my T/O bearing or Mainshaft bearing went bad and needs to be replaced...I don't want to have to pull the engine again, so my question is....How can I remove the transmission while the engine is still in the car, I have tried once, and it appears to not be enough clearance. I used to be able to do this with my KA but am having no luck with this engine. Does anyone have any tricks, because everywhere I searched people say slide back and remove, and that's not happening
