sr20det trans leak??
themeanest240
Car: 1991 240sx
i have been noticing small amount of trans fluid under my hatch so i got under to look and it just confused me more and more. here are some photos to try to help pinpoint where leak or leaks could be coming from[IMG][/IMG][IMG][/IMG][IMG][/IMG]idk if a seal is where the d/s connects with trans? maybe thats bad and causing the fluid to run all the way down the the others spotsany help is greatly appreciated!thanks
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
If it is the rear transmission seal then you can just remove the driveshaft, take out the old seal and place a new one in. How's your fluid level, if it's too full it will leak?
Justin35ll
Car: s13 coupe sr20det
The rear trans seals go bad a lot, mine leaked all over the garage floor when I got it. I drained the fluid and pulled the seal. Gotta pick it up tomorrow actually.I guess it could have leaked from the rear and dripped down to the center, but I'm not sure.If it was mine I would wipe it clean and let it sit and try to see where the fluid is coming from
aznrib
Car: 1995 240sx
if its oil then it could be the rear main seal. If its gear oil then its the rear transmission seal
redsx13
Car: 93 240sx 03 350z
its the trannny to driveshaft seal they go out all the time
fast_s13
i would just drop thetranny and put front and rear seals in it... then you know you have the leak fixed
themeanest240
Car: 1991 240sx
if i knew how to drop the transmission and even had the tools to try i would have it fixed and the throw out bearing fixed. the whinning the t/o bearing causes drives me insane let alone leaksthanks for all the help guys
themeanest240
Car: 1991 240sx
does anyone know what seal i need to get for d/s connection?could i just go to auto store and get for ka trans?
positron1
The seals and gaskets are the same for the SR and KA transmission's.
Justin35ll
Yeah, I went to the store last week. Got a rear trans seal for 10$ and oem throw out bearing for 20$ (nissan pathfinder)
redsx13
dont waste your time dropping the transmission if you dont have to, replace the driveshaft/trans seal first.
snake240
Car: 92 hatch SR20DET
if it looks like fluid is coming from top and running down, the shifter cover gasket is leaking, especially if you added synthetic transmission oil.
