SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Thu Sep 04, 2003 3:01 pm
The Type X didnt get a special ECU. All the Later (1997-1998) 180SX's with SR20DET's recieved the J4 ECU. So the true question is, will the J4 ECU run an earlier S13 SR20DET?
#62, #63, E5 and E6 are the redtop and early blacktop (1994-1996) ECU's. Their serial numbers are 23710-50F**, the 23710 means it is an ECU and this number will be found on all Nissan ECU's. The 50F** (last two are random numbers like 10 or 05) represents the chassis that the product was first used on. So the 50F represents the S13 Silvia/180SX, though you will find some parts on the SR that have a number 52F**, those are also for the S13 Silvia/180SX from what I can tell.
The serial number for the later model 180SX is 23710-60F** and many of the parts such as the wiring harness are marked 60F**. Therefore the parts were redesigned. I do not know if that means they will not run the 50F-52F series parts but they are clearly different as people have mentioned before.
