SR20DET TPS Questions
turboimports
question for my redtop s13 sr20det.anyone know about the 5/6 plug on my harness for the tps? i have one like this, some say it only comes with the 50mm throttle body. wich im not sure if mine is or not. it doesnt hook up to my sr20det wiring harness, because my harness is only for 3 plugs or something. some also say that i can replace the tps with one from a 91-94 usdm sentra ser? is this right? bolt up?
thanx
-Lor
turboimports
NY S13 SR
6 wire TPS plug means you have an automatic harness, no big deal. You can convert and solder the wires directly onto the pins of the 3 wire MT TPS.
DET FSM will show you which wires go where. Call us and we can fax a diagram to you if you need it.
__________________Jeff HHeavy Throttle[email protected]
turboimports
you can email me a diagram at [email protected] if you have a copier. thanx
-Lor
