aznxkrnxboi »
https://forums.nicoclub.com/aznxkrnxboi-u33710.html
Sat May 13, 2006 4:56 am
I need the torque specs for exhaust manifold, intake manifold, valve cover studs, cam journal torques, head studs, crankshaft pulley, alternator pulley, water pump pulley.
I need the timing specs. Is there a pin where u have to jump to set the base timing for the sr20det (take the ECU out of equation)some cars such as toyota's and various other cars require u to jump a pin on a terminal or a ECU itself. To stop the ECU from making timing adjustments while ur trying to set the time. AKA base time.. As far as the total time about the 3000 rpm thats for all out racing it does give u more power in the rpm ranges where it counts but results in a sh*tty idle.
