Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed Oct 22, 2008 4:58 am
Honing isn't the same as machining. You don't need a torque plate if you're just honing. Honing also doesn't affect the head gasket or head studs. It's primarily done to help the rings do their jobs.
Now, if you were boring the block, I would recommend having a torque plate, but since SRs are designed as closed deck blocks, it's not critical to have one.
