Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Oct 28, 2006 2:31 pm
300ZX axles won't work. They're too long.
I have no clue what you've done to your motor, so I will assume you've done some mild tuning and upgrading to it. There is NO way that you could split your rear subframe with a mild setup, or even a pretty hardcore setup. You just have had bad luck with defected parts. As far as aftermarket driveshafts go, depending on the manufacturer, the quality could be hit or miss.
If you want an upgraded axle, get J30 axles. They're thicker than stock axles, and they're the right length.
