Hey this exact problem is happening with my ka24de and was going to post about it. I can also make the same slap noise with my finger with the chain hitting the guide. So, same question tensioner is bad? Also one of my stupid friends dropped a bolt from the valve cover and it landed on the bell housing, stuck behind some wires no way to get it. Anyways you think I'll be fine running it with 4 bolts? 2 in the front 2 in the back? Back center is the one missing, It's not leaking or anything from what I can see. Car is a '95 automatic se if that matters/helps. Just got it 2 days ago too, loving it so far and don't expect it to be perfect.
Thanks guys
