SR20DET TIMING CHAIN RATTLE
wangan_cruiser
Car: 1991 nissan 240sx fastback rip 2009
1993 nissan 240sx jdm aero conversion sr20det
1990 nissan 240sx
1996 nissan pathfinder se 4x4
2001 nissan pathfinder le 4x4
ok
to start this problem i have a brand new set of timing chain kit for the sr20 with the updated timing chain kit and tensioner
im having this rattle on the top of the valve cover.
what i did so far is
swap tensioner
then it went away.
then it came back.
swapped the new one
it went away
i drove it around the block for a test drive
it came back.
im tired figuring this thing out. ive search here and theres a bunch of thread came out with no fix its just bunch of ideas but no one ever fixed it.
and pls read the title before posting because some people always get it mistaken as a KA problem.
400whps13coupe
Car: 1989 240sx coupe
is tensoner installed properly? remove chain guard between the cams see if that helps as cams load and unload between strokes the chain has just enuff play to slapp the guard
