So I was going to set my timing today on my redtop sr20det, need it to be at 20 degrees btdc for my ecu tune. My car sorta "skips" sometimes at idle I guess thats what I'd call it, thought it might be because of the timing being a little off. So before doing anything I just hooked up the light to see what it would read. I did not unplug the tps i just left everything alone, I was told that it can be done either way. So my car was warmed up, no reving or anything just sat for a complete mins and was idling at about 950-1000 rpm. which is slighty high i believe. So here's a video of what it was doing at 950 rpms...
Sr20det idle - YouTube
Kinda hard to hear but when it goes back and forth from 20 to 15 you can hear the "skipping" ..What could be causing this? ...but after that I barely revved it up and then my car stayed idling at 1200rpms. I cleaned the IACV yesterday with compressed air the screw is completely closed. stayed at 1200 yesterday also and used to stay at 1200 before cleaning but the screw was not all the way down. Maybe a vacuum leak? Anyways here it is at 1200... its where I want it to be but its idling too high.
video-2013-04-11-18-59-00 - YouTube
So I'm trying to figure out whats going on here and how to fix it?
But that could be the least of my worries... I now have a leak which i think is coming from the gasket above the oil pan. Dont know what it is called and dont know what is leaking. I literally just changed my oil like less than 50 miles ago and this stuff is dark, seems very thin almost like water, doesnt smell like straight oil and dont smell coolant in it either, I honestly can barely smell it, really no idea... just hope my headgasket isnt leaking but I have no other signs of that. I'm almost thinking I might have a leaky injector so its gas/oil mixture. I do notice a gas smell from my car when my car is on but I just thought it was just because I've got straight pipes
Thats the gasket where I think its coming from and dripping down. What is this gasket? Is it hard to replace? And below is just how much came out after about 10 mins of idling.
Sorry for all the questions, I try to figure everything out with out asking first but really just didn't know what to do this time and the timing is just confusing me. Any help is appreciated, thanks
