sr20det tachometer
Naloos13
Car: 1989 S13
I have an 89 w/ a blacktop sr. But....i have no tach signal coming into my ecu....i have searched everywhere. Has anyone had this problem and solved it. Does anyone know where exactly the tach signal comes from on the motor?
s_13_steve
Car: 89' Hatch with a mad tyt3 HICAS diff y0
89''s factory tach is for a SOHC. SR's are DOHC so you need a tach that reads a dual cam pulse (like out of a 91 or 92 )
EDIT: search harder, this question comes up almost DAILY on this forum.
CrypticScorpio
Car: 1992 240sx SE Hatch
common problem. even with a dohc tach you still wont get a reading. ka uses a distributor to read and sr dosent. you need a converter to read it. cant remember what it is... post in sr20 forums..... may get a better awnser.
Naloos13
Car: 1989 S13
I have searched...like i said...incessantly. I dont understand why it being a sohc would have anything to do. I know the stock tach wont work. Which is why i am running a Defi tach. Which does work with no adapter on the SR. The tach signal comes from the motor to the ecu, and then out to the dash. So yet again, there should still be signal coming from the motor to the ecu, which i should be able to tap into. I have posted everywhere, i have searched everywhere, and no one has a solution. please help if you can.
CMG
Car: 1989 240sx Hatch w/ Redtop
Naloos13 wrote:I have an 89 w/ a blacktop sr. But....i have no tach signal coming into my ecu....i have searched everywhere. Has anyone had this problem and solved it. Does anyone know where exactly the tach signal comes from on the motor?
If your speedo works, then the tach signal should work. Did you try to read the defi instructions or call customer service?
