sr20det
dnme.trigun
Car: 97 240sx
hey, was wondering, what's included in an sr20det swap.. including all the parts needed, picking up sr from this autoshop but i need to make sure i get EVERYTHING that i need. and i mean everything.. thnx your help is appreciated
Silvia007
Car: 93 Nissan 240SX SE Fastback
EngineTrannyWiring harnessECUIgniter ChipCoil packsintercooler pipingintercoolerdownpipeBOVBoost controllerHeater hosesTach from 91-93 if chasis is 89-90
I think that's about it.
zombieman
boost controller not needed, but recommended.same goes for tach. you don't need a oem one, aftermarket have higher rpm readings and will do just fine or don't hook one up like what i'm doing right now.
also you'll need either a sr20 radiator or just custom your own hose to make it work with the stock radiator.
make sure you get a power steering pump, non hica if yours is already not equiped with it. and hica one if youres is equip with it.
