SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Wed Dec 26, 2007 2:36 pm
If you have the lines off the turbo you can look at the turbo and figure it out. The oil lines lubricate the shaft of the turbo so you can actually see the shaft through the hole for the turbo. The other oil hole is on the opposite side. The water lines run around the outside of the shaft if you look in those holes you will see an open shaft area for water to channel through. The other side of the coolant line is on the opposite side.
