SR20det swapped in but wont start...
ytfeL
Car: 1995 Nissan 240sx
Now before any flames begin, please let me say that I have looked, looked more, and looked even more before I decided to post here. I simply cant figure out what is wrong. Okay I started out by buying a new ecu, because the one that came with the motor was fried. once I received another one I checked for codes and it was giving me a code 11 which is the CAS, so I replaced it with a new one as well and timed the engine. I still wasn't receiving any spark, also my spark plugs werent smelling like gasoline, but my fuel pump is pumping and my lines arent crossed. At the time i decided to focus on getting spark first, so I went on to check my igniter, sure enough that was bad too. I went on and grabbed a Z32 igniter and wired that in and still nothing. I've checked every single ground thoroughly. I've been at this for about 2 months now. I've checked every thing that was the problem for everyone else on other forums and I've still got nothing. Any insight on my problem would truly be helpful. Again I'm sorry if I'm cluttering with another SR troubleshoot thread, but I am seriously in need of any help.
Silvia007
Car: 93 Nissan 240SX SE Fastback
S14 sr in S14 chasis?
bestint
Car: many nissans and a porsche
was this an auto to 5sp swap?
ward28465
Car: 95 240sx blacktop SR
i had a simular problem with my sr swap, it would turn over but wouldnt start, it ended up being a wiring issue, not everything was wired correctly, so if your not possitve the wiring is right, read up and double check everything... hope that helps.
