blkvrtswp »
https://forums.nicoclub.com/blkvrtswp-u185208.html
Sun Sep 02, 2012 7:42 am
You will use all the car's fuse boxes.
Use the SR engine main engine harness (ECU, CAS, MAF, O2 sensor etc. - goes thru the firewall) and upper engine harness (injectors / coils etc. plugs into main engine harness).
If you have the SR lower engine bay harness (alternator, starter, reverse lights and speedometer etc.) you can use it but you can also easily adapt the SOHC KA or DOHC KA lower harness to work since almost all the plugs are the same.
For specific wiring, there are lots of forum threads just look in the stickies and search. If you are missing any big parts of the SR harness you can always buy a shiny new conversion harness from Wiring Specialties.
