The cover art is not ready, regarding the editing, most of the extra work was need for the wiring section which was done this weekend.BuLLeTdrift wrote:Is it bad that the trailer turned me on a lil bit?
lol i just finished my swap last month, but I would be interested in watching this to see where i went wrong on things. Also so I could help with friends.
On the ordering page, it says cover and some editing will be left out, when will it be finalized?
Thanks for the tip. We will probably address this in our RB Build DVD.duffman1278 wrote:^^^ Yup Yup. I forgot to mention this earlier but maybe you should REALLY note on the video that if you decide to pull out your injectors for any reason, or the fuel rail out, to REPLACE the o-rings. I learned my lesson
Are you S13 to S13? If so the documentation is there. We can also help you out on this thread or by email.schanne wrote:Pulling the motor out to replace thos hoses sux! I feal your pain
I'm interested in the dvd but mainly for the wiring. Does it have a full wiring installation part? And what is missing ?
Thank you, if you need any tech help just post here.schanne wrote:S13 to S13. But it's a late model blacktop S13 (J4 ECU) So some things are a lil different. Thanx! I'll be picking my copy up here shortly.
The S13 to S13 wiring should be easy to follow on the video since the diagram and titles were added.schanne wrote:S13 to S13. But it's a late model blacktop S13 (J4 ECU) So some things are a lil different. Thanx! I'll be picking my copy up here shortly.
