zombieman »
https://forums.nicoclub.com/zombieman-u7836.html
Sun Oct 31, 2004 8:19 am
yes, you will need a (bov)blow off valve if you're using an aftermarket intercooler with its piping. while it's true that a bov is not needed to run a turbo car, but it will save your turbo life big time.
a boost controller is not needed for the car to run properly. but a boost gauge is however recommended.
you will need a downpipe if your motorset doesn't include this.
it looks like the motorset doesn't include the power steering pump, this will be a major problem if you're use to the "power steering life". so get one that's not a hicas.
using powersteering lines and resevior from a 91+ is not neccessary unless you're going for a more clean look. ghetto rig it like us cheapskate people
last but not least is the ac unit. you might want to do a search on this one. while some say you can make a custom bracket to fit the stock 89-90 ac in the sr20, after doing a few fitment test, i came to the conclusion that it will not fit in the engine bay without hammering in or cutting a off some sheet metal on the driver's front near the fender well for clearance. so i decide to leave it hanging there and not use the ac.
i know this to much to list, but i hope it helps you, so you won't encounter into problems like i did while putting my motor into a 89 s13 after doing research and getting some false info.
