SR20DET swap.
CoreyS13
Car: 1989 240sx Sil40
I am swapping a S13 SR20DET into my '92 240sx, I am not 100% sure on where these following 3 hoses run to that are located under the intake manifold.
Thanks in Advance.
Hijacker
Car: '92 240sx Convertible
'94 F-150
1 - turbo coolant line. YOu have it turned around the wrong way.
2 - IACV on the manifold
3 - Throttle body port. Furthest from the block
duffman1278
Car: 89 240sx Hatch, the wildcats!
This might help you
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
I would cap that return coolant off and get an s14 waterneck and s14 stainless turbo oil and water lines
JTunedMotorsports
Car: 1991 240sx
I ask good questions wrote:I would cap that return coolant off and get an s14 waterneck and s14 stainless turbo oil and water lines
yes i cut off the cross over tube for s13 water line and just ran the heater hoses straight into the heater core...got a s14 water neck and lines and called it a day..makes things easier for turbo replacements..
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Both of my lines at #2 are capped off with my makeshift paint cap offs. If I were you, I wouldn't bother running those to the iacv. It just warms up your intake manifold.
If you desire to cap off number 1 instead of number 2 cold side, you could do that because number 1 is pointing the wrong way anyway. Either way, a line from number one or the cold side of number 2 needs to go back around the engine to the turbo coolant line, you will find it.
Number three is self explanatory, don't know why they cut it musta been a bunch of dummies removing this engine lol.
