Good advice Justin35ll
do a Gasket rebuilt, Metal H/G and ARP Studs definatly and REPLACE the Oil pump!
240life wrote:The black-top he speaks of is a s14 or s15 sr, the also come with larger fuel injectors and and Nissans Vtc ( search FAQ for more info) a s13 sr is exactly the same unless it is the type x black top ( research more ) they are all good engines ( imho the s13 is better if you are upgrading, better head design, not paying for VTC that could be removed when upgrading cam)
Only S15 SR's came with larger injectorsS14&15's came with VTC S14 came with BB T28S15 SR also did to but with a slightly larger exhaust size
Like 240Life said S13 Sr's are a little better if you plan on running more than 350hp Parts are more cheaper/abundant and a few KA parts can cross over. Also wireing is alot easier than the S14 or S15
Correct S13 Red Top SR and S13 Black Top SR (Kouki/Type X) are exactly the same except Type X Cams are a little more agressive (slightly) and Wireing ECU Pin out is differnt
S14's VTC become useless over 350hp, there are 2 differnt electrical systems for S14 sucha as MAF's and ECU's so trying to find correct parts is difficult
