sr20det swap
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
shazza
Car: n13 pulsar
is it possible to put a sr20 from a n14 pulsar sss into a 1994 n13 pulsar Q
please reply to this or my email adress at [email protected]
nametakennow
Car: '06 MINI Cooper S
Shouldn't be difficult. You'll need the wiring harness, ECU, transmission (double check part numbers to see, they may be the same), and front/rear motor mount crossmember (again, check part numbers) from an N13 SR20DET-powered Pulsar to make it work, though.
Is your Pulsar front wheel drive or all wheel drive? Is the model you're getting the DET from the same? That may be an issue in terms of transmission.
Unfortunately, we don't have Pulsars here in the US, so I don't know the full list if what you'll need. However, there are some members from other parts of the world who have Pulsars and may see this thread and drop in to help.
Welcome to NICO!
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
