sr20det swap
NsB 200SX
Car: cars
okay, i dont have it yet, but im getting a 96 200SX se-r and ive seen people that ahve done the sr20det swap but i ahve a question, on streetimports.com it says available with RWD or AWD transmission's so wouild i have to convert it to either RWD or AWD or can it stay FWD just curious, and also what would the horsepower be for the year and model cuz it says 205hp-250hp depending on the year and model... thanks in advance
eddie
NsB 200SX
Car: cars
sumone has to know the answer to this question.......
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
You need the one that comes with the AWD transmission. You have to use your transmission though.
The AWD transmission engine is transversly mounted, that is why you need it. So you can mount it to your transmission. The RWD transmission engine is a little bit different, and mounted longitudinally.
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
EZcheese15 wrote:You need the one that comes with the AWD transmission. You have to use your transmission though.
Ditto to what Torry said. Basically you will need either a Bluebird motor or a Pulsar GTi-R motor (this one more desirable).
NsB 200SX
Car: cars
thanks again for your help
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
http://www.sr20deforum.com is also a great place for swap info. Good luck.
