silviamirage »
https://forums.nicoclub.com/silviamirage-u2425.html
Sat Nov 16, 2002 6:08 am
implicit-'95 Jetta GL, 2.0 litre 4cylinder. The power's not too bad and it handles relatively well at high speeds for the condition that it's in, but it needs alot of work: The suspension was already too soft, but now it can be dangerous when going through tight turns at high speeds, the wheels need to be replaced (a bit dented, driveable easily, but still worth replacing), the sunroof isn't working, the muffler needs to be replaced, and it has alittle other cosmetic problems. All in all it's not that bad, but it lacks the pep of a japanese car, and feels too much like a minivan in its upright stance.
s13240-Ok, I messed up my terms, something to do with me doing research on about three things at once while posting. While I messed up terms, the lines will still not interchange. Why they won't, I don't really know, because, like you said, I don't even have a 240 yet. However, I do know that SCC wrote that I'd need to change the lines over, and the only person that is refuting that is you. Although I don't doubt that SCC could have been wrong on occasions, they are a magazine that does project cars like this on a regular basis, has writers with at least decent proficiency, far above any other import magazine (indicating intelligence), and, unlike you, they post pictures of the work that they did on the internet, so I know that they actually have done the swap on an '89 240, unlike you. You may have done the swap, but you probably didn't do it on an 89 or 90, since you didn't mention it. Furthermore, I see no reason why SCC would have said that they had to use the longer power steering line if they didn't have to, and I doubt that they would have taken the trouble to if they didn't have to.
My question is: How the hell do you know? Did you actually do it yourself? Furthermore, there are other people who sift through this forum who would definitely know the answer to this question, people who have done the swap themselves on an '89, and until they tell me otherwise, I'll believe SCC over you.
Also-don't insult my intelligence. I'll leave it at that, before I result to more inflaming sorts of report.
