Postby
matt0941 »
https://forums.nicoclub.com/matt0941-u2842.htmlMon Dec 30, 2002 6:26 pm
I hope to soon be doing a redtop SR20DET swap into an S14A. As I will not be leaving the engine/car untouched once the swap is completed, I was wondering what should be done (or gotten out of the way) as long as the engine is still uninstalled. I have done a couple of searches but have not gotten the answers I am looking for. I plan on upgrading the turbo and would like to be putting down up towards 300hp once the engine is installed. So my question really is: what should I get taken care of before I put in the engine, so that I don't have to take the engine out again a month later (ie say for larger injectors)?
Postby
lucky »
https://forums.nicoclub.com/lucky-u2041.htmlMon Dec 30, 2002 6:26 pm
You don't have to take the engine out to install injectors, intake manifold, turbo....the only thing you would really need to take the engine out for is if you were putting pistons, rods, crankshaft, etc. in. You can even build the head without pulling the engine.
Postby
matt0941 »
Guess I was too used to other forums (Supras) that I thought it was a must to pull the engine in order to swap a turbo. But do you think that I should resleeve, new cams, etc. before swapping it in? What is else is very common for 300hp (+ or -) as far as engine work while the motor is out. I am hoping to get low to mid 13 times (of course I will be changing tires/suspension.
Postby
SR20DET240 »
https://forums.nicoclub.com/sr20det240-u1932.htmlMon Dec 30, 2002 6:26 pm
Almost anything you do will be easier with the engine out. Heck its easier to change the plugs with the motor out because you dont have to bend over the front bumper! :pface
I would say do the clutch. Also if you are gonna do a high volume oil pan, best do it while its out. If you are going to make power via high boost, you will eventually need a head gasket. Not a bad idea to do it while its out. Its not that hard to do while the engine is in, its just more convenient. Anything else can really be done while in the car w/o too much trouble. Anything I'm missing?
Postby
Redline240 »
https://forums.nicoclub.com/redline240-u3445.htmlMon Dec 30, 2002 6:26 pm
Well this probaly goes without saying but you can take care of a lot of things and just use them on the KA....like relocating the battery to the trunk, upgrade fuel pump, swap in a LSD, slap on a SAFC, gauges, etc......that's my plan anyway....
oh and there's no need to sleeve the block if all you want is 300rwhp.....maybe 400rwhp.....
Postby
matt0941 »
Hey lucky, i watched yer vids, awesome single BTW, but are u sure you dont have to take out the engine in order to upgrade the turbos. Because arent they barried in there, i am pretty sure you can't even see them on a stock TT.
Postby
lucky »
matt0941 wrote:Hey lucky, i watched yer vids, awesome single BTW, but are u sure you dont have to take out the engine in order to upgrade the turbos. Because arent they barried in there, i am pretty sure you can't even see them on a stock TT.
That's what they make tools for You can actually take the entire twin turbo setup off without too much work.
Postby
matt0941 »
Well Lucky and "I H8 UR DSM", since I have read your other posts and value your opinions, what do you guys think that is more common (for a good reason) to the SR before the swap for low 13ish times. Resleeve + crankshaft +clutch? Thanks (and I didn't know that you could swap the entire turbo setup on a Supra w/o removing the engine, I just assumed since alot of the people I know did so)
Postby
matt0941 »
So there is not much chance in cracking the engine block or other damage to the internals with high boost on an SR as long as the air to fuel ratios are ok and exhaust temps. are fine?
Postby
Redline240 »
the block will handle a lot more than the T25 can dish out....i believe around 22psi and roughly 400rwhp....don't hold me to that, it's just what i've read.....
Postby
matt0941 »
So is it unheard of ruining a motor do to boosting high on a T25, because I would like to be safe, but if it is extremely rare that the stock motor would not be able to handle it, should I bother?
