SR20DET Swap. Need Help.
shane7213
Car: 1990 Nissan 240SX Coupe
I have a 1990 240sx coupe (non fastback) and the factory KA24E engine is blown and the transmission is basically shot (owner before me treated her terribly). I am going with a cheap performance fix by going with a red top SR20DET. I need to know if i need aftermarket mounts (if so where to get them) and if there is anything else i need to replace with aftermarket parts to make her run again. I am new to the Nismo world and have never worked on a Nissan before now, so please, no flaming. Any help is greatly appreciated.
Kouki KAT
Car: '97 240sx SE
Hey man,
There is a LOT of information on SR20 swaps on the site, you just have to search for it (even easier, there are stickies that will take you to the right place).
But, long story short, you don't need special mounts. The SR20DET is a direct drop in motor (though you should probably just buy some new motor mounts while you have it out of the car anyways). Besides that, you'll need new heater hoses, which a whole bunch of places sell, and some kind of intercooler plus piping (also widely available). Also, make sure you get EVERYTHING with the motor/transmission (like ECU, wiring harness, turbo, manifolds, ignitor chip, CAS, etc.).
You should definitely do your homework though, because you'll be throwing in a good amount of money to get your new motor running right. But you are in the right place.
P.S. Don't put post anything else like this, or you'll be sure to get megaflammed.
shane7213
The only good intercooler i could find says it's for PS13 (SR20DET) would that work?
I aslo found a greddy intercooler for a lower price but it says under vehicle applications it works with 89/98 180sx and 89/93 Silvia and if i'm not mistaken mine is not a silvia its a zenki. Would this intercooler kit work?
http://www.frsport.com/Greddy-....html
that is the link for the second intercooler
I am getting the parts through frsport.com and i'm hoping you say the intercooler will work if not do you know a website that has an intercooler for the S13 chassis with S13 SR20DET?
Modified by shane7213 at 6:47 AM 10/12/2009
Modified by shane7213 at 9:23 AM 10/12/2009
gigabit240
Car: 92 s13 hatch -sold
98 s14 kouki -current
shane7213 wrote:The only good intercooler i could find says it's for PS13 (SR20DET) would that work?
Any intercooler will work in any car. You just gotta figure out how to fit it. Sr20 is the easiest motor swap for the 240 besides a stock swap. You might wanna get a new clutch if your buying an older sr. And silvia/180/200 are all the same thing.
moulton712
Car: coupe, hatch, both s13s
you need to watch out when you say 200sx.
200sx means a few thingss12 chassiss13 chassis is select countrysb14 chassis in America 1995-2000
two203
I am actually looking into the same thing..
If i already have the motor and shell what else do i need to buy to make it reliable and legit swap. I was thinking about making a thread because my buddy has a motor in his garage that he is getting rid of and i need to know the budget asap. thanks for the help.
edit: it is a s14 kouki shell
gigabit240
moulton712 wrote:you need to watch out when you say 200sx.
lolz very true200sx is European market variant.
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
I recommend buying the swap dvds from www240sxtechdvds.org They have helped me out quite a bit. It shows about everything you need to know. I wouldn't say it's a cheap swap. I have quite a bit invested and I am still not finished buying parts. You should look into that before you get in to far over your head. If your new to working on cars or 240sx's for that matter. I bought mine a year ago and both motor and transmission have gone. They are just old cars man. Doesn't mean they got treated bad.
