sr20det swap issues
kd200sx
Car: 1995 200sx se
things different on my motor that mite cause the issue idk tho. 1. i changed my sr maf to a 300zx maf.
2.when i droped the motor i dropped the motor while the tranmision was already mounted to the car. so i just dropped the motor and aligned it to the transmission then mounted and bolted everything up. it was quite difficult to get in. i belive i bent one of my pressure plate fingers about at a 7 degree angle wile trying to get the motor on the transmission. 1-5 gear works fine.
3. i have a safc that i had always had on the car but i dnt know if it needs to be tuned when the maf is switched over
Problems i had after the swap 1. the car starts up fine, and it is idling pretty high from what i hear. but the issue is when i give it gas even when in nuetral the idle drops as if the car was going to shut off. this occurs as soon as i touch the gas from 0% throttle all the way to 100% throttle.
2. my reverse is jammed for some reason i can go into 1st-5th gear just fine but it wont go into reverse.
kd200sx
Car: 1995 200sx se
does anyone one know whats wrong with my issues on my car
